2 Comments
  1. Mike Glatzel on September 26, 2016 at 17:25
    Why do you need the heat cable? Are you worried about the temperature control not working correctly and getting too cold?
    • Elco Jacobs on February 23, 2017 at 15:46
      The heater is needed when the temperature outside the fridge is too low or the beer is not generating enough heat from fermentation. It is also used to raise the temperature when fermentation is nearly done to do a dyacetyl rest.
